canoe_on_top
Dec 02, 2014Explorer
Consider a 1 ton SRW as opposed to a 3/4 ton. Often the difference is an additional spring pack on the rear axle that doesn't engage until the truck is loaded enough to drop to that point. So, unloaded, the ride should be about the same as a 3/4 ton but you will have a higher GVWR on the truck.
