philh
May 11, 2015Explorer III
Towing at Max
Brand new to camping and travel trailers, but not towing. Wife decided we are going to start camping... so you know what happened next. '07 Dodge Charger, and based on a unique configuration, wh...
kmbelt wrote:
You can only go by the 5.7 here. According to this, it is rated for the 3800lbs like your magnum is.
Ignore your 4400 number as that config is not available in the US. the reason it is 4400 is probably the weight difference in the engines/tranny's. The CRD is an aluminum block as the 5.7 is a cast-iron.
