philh
May 11, 2015Explorer III
Towing at Max
Brand new to camping and travel trailers, but not towing. Wife decided we are going to start camping... so you know what happened next. '07 Dodge Charger, and based on a unique configuration, wh...
proxim2020 wrote:kmbelt wrote:
You stated "Looking for suggestions and/or concerns with my set up."
Obviously you were not looking for the info as MANY people have told you about their concerns and all you seem to repeat is that you are an engineer and know it will be fine.
Have fun down the road when
1. your hitch rips the rear of your car out
2. you rear-end another vehicle due to not being able to stop
3. you lose control and flip due to your car not having enough mass to control the swaying you will likely receive while towing
4. you burn the tranny out because it is most likely not built to haul the load unless an exterior transmission cooler was added.
Hopefully during all of this, you do not injure/kill any other motorists and by-standards, because you obviously do not take into account their safety around you.
And if none of this "doom and gloom" happens will you gladly eat crow? So far no one has given him any good hard facts on why this can't be done. Most of the advice has been "I wouldn't do it," "It's a unibody car. You can't tow anything with a unibody car," "You'll be over your limits," etc.
I got to say when I first started reading this thread I was highly skeptical that this combo would be possible, but the OP and others make some really good points. Plus a similar combo is alive, well, and operating just fine. While towing with a Charger would make for a very unconventional and maybe less than ideal TV, that doesn't mean that it can't be done. You don't need a truck with 6 wheels for everything.
I have a little econobox with a stick that has a tow rating of 0 lbs. The manufacturer didn't even make a hitch for it. A few days after I bought it new I put an aftermarket hitch on it. I've put so much stuff behind that little car, even a 600lbs gun safe. Over the last 8 years I've never lost control, flipped, or rear ended someone while towing. Never actually put myself in any of those situations really. The hitch has yet to be ripped from the car. After 168,000 miles, I'm still on the original clutch, engine, and transmission without one problem. Pretty good for a car that routinely exceeds its tow rating.
