Golden_HVAC
Feb 17, 2015Explorer
So are you concerned about going 2' longer? If the weight where exactly the same, it would tow just the same.
Are you concerned about the 600 pounds higher GVWR of the next trailer? The overall GCW will only increase by what? 5%? That is really no change at all either.
Diesels like the low RPM range. Especially the Dodge, it is not high RPM engine like the V8's. The larger diameter piston and longer stroke require a governor at a lower RPM.
You stated "Slow to start out" and yes the taller tires prevent quickly moving up to the 2000+ RPM that starts to make the full 300 HP output. But still it will cruise along at 60 MPH in drive, and make plenty of power in the right gear.
It will work fine with your truck. The truck should have plenty of weight capacity too!
Fred.
Fred.
