MFL
Jan 28, 2017Nomad II
You should have an idea from current trailer towing. If it tows that weight easily, adding 5' and 1,500 lbs should be doable, if adding the same gear/weight from old trailer to new.
Payload of truck, can be an issue with heavier tongue wt. Passengers, things in truck bed, plus added hitch wt, can make a soft suspended 1500 not handle very well.
Look at all truck numbers, GVWR, RAWR, payload sticker. The tow weight rating is more about engine/driveline.
Jerry
Jerry
