lawrosa
Aug 12, 2015Explorer
Not a mattter of what the car can pull ( 3500 lbs), its the tongue weight you need to be concerned about.
At 380 lbs for the star craft youll probably be over the limit. when propane and gear/people in car...etc
You need a WD hitch at a minimum. Dont know whats on there now but IMO get one period.
Even though its rated the same as the hitch you may have, the WD hitches allow WD bars to shift the weight to trailer and front of TV..
Mazda WD hitches.
This way if you have a 400 lb tongue weight you may be able to take 100 lbs off it.. example
As I stated in another post look at the jaycos, But the start craft AR ones are also what you should be looking at. Aluminum sided is lighter..
Youll be glad you have a closet. This model is 315 tongue/2760
jayco 185 rb
Starcraft AR one
305 tongue/2865
ar one 17rd
WD hitch!!!!
Mazda WD hitches.
jayco 185 rb
Starcraft AR one
305 tongue/2865
ar one 17rd
WD hitch!!!!
