rexlion
Aug 13, 2015Explorer
SilverEscape wrote:
A trailer that lists a 2700 dry weight on in th brochure is likely to weight 2900-3000 when it arrives. Load it and you're at 3700 packing lightly and without carrying water. Add a tongue weight of 480 and you're at 4100...
I think this is a bit inaccurate; the hitch (tongue) weight is included in the 2700 lb dry weight already.
That said, I cannot stress enough: do not buy that trailer! A dry hitch weight of 380 lbs does not include your LP tank and probably not your battery, either. And where is the fresh water tank? Where is the water heater? Water weighs 8.3 lbs per gallon, so if the tanks are in front they will add more weight. Realistically your hitch weight when ready for camping will be at least 450 lbs, possibly as high as 600 lbs!
I once had a TT with a 385 lb listed hitch weight. Front water tank. My SUV had a 600 lb hitch weight limit. I used an Equal-i-zer anti-sway hitch. I bent a rear spring on the SUV!
Your Mazda would do well with a Scamp, sold factory direct from Backus MN. Or a Taylor Coach trailer, made in Ontario. Or a Chalet or Aliner hard-sided popup (see my picture). Or an Escape, factory direct from Chilliwack BC. There are other options, too. But I guarantee you, that Starcraft (nice as it is) could damage your Mazda's rear suspension, or possibly rip the hitch receiver off its mounts and send the TT careening head-on into traffic. The only way I would buy that TT is if I were prepared to spend an extra $2000-$3000 having the receiver and suspension modified... assuming it is possible to do so!
