Can't speak for anyone else, but my Sunday is just fine!
With the trailer you're looking at I think it will do ok but pushing the limits on the truck. You have enought hp, but suspension is borderline. Most people figure more like 1000-1500 lbs of stuff in the trailer. Definitely use a wd hitch. If you get one that does not have integrated sway control, use 2 friction bars. Also check your tires. P rated tires will be squishy and not handle well. Get LT tires, preferably E rated. You can run them on low pressure when not towing to soften the ride. I run 45 lbs on mine unloaded. You will also need a 7 pin elec connection with brake controller if you don't already have it. Start saving your coins for a heavier truck to match your next trailer that will be a little longer and a little heavier. Enjoy the new toy!!!!!!
