Cummins12V98 wrote:
ib516 wrote:
mike-s wrote:
Most manufacturer's now rate using the SAE J2807 standard, which is very far from "perfect conditions", and is probably at the difficult end of what most people encounter unless you regularly tow in the mountains.
This is the correct answer.
I concur. But people need to understand that is NOT a 5er as the pin weight will exceed the RAWR. Most likely a gooseneck is what is tested at 18k.
Last time I checked a gooseneck hitch was still a bed mounted hitch. so it still needs a higher % of HW vs a ball or pintle which can be less....
Still the issue with the J2807, is the performance specs, if something meets the absolute minimum, ie the 12% grade, you will/may not be pulling a 14% grade. most of us pulling 14% grades, are not going faster than 35-40 mph! Not does one plan to go faster than this! Even the 18% grade in front of my sisters house, I do not plan to go much over 25-30mph, granted a residential road......or the 25% grade on the north side of Queen Anne here in seattle on Queen Anne ave! doing 25 mph you are doing good!
Marty
