thehippie
Oct 13, 2018Explorer
Towing capacity
The ram 2500 Cummins ctd has towing capacity of Almost 18,000 pounds. Is that on flat roads Only? How about towing uphill? Will it still be 18,000 pounds?
bikendan wrote:Most manufacturer's now rate using the SAE J2807 standard, which is very far from "perfect conditions", and is probably at the difficult end of what most people encounter unless you regularly tow in the mountains.
Towing Capacity numbers are not real world numbers.
They are from towing in perfect conditions and with something that offers very little air resistance.
That way they can inflate the numbers.
