thehippie
Oct 13, 2018Explorer
Towing capacity
The ram 2500 Cummins ctd has towing capacity of Almost 18,000 pounds. Is that on flat roads Only? How about towing uphill? Will it still be 18,000 pounds?
Cummins12V98 wrote:ib516 wrote:mike-s wrote:
Most manufacturer's now rate using the SAE J2807 standard, which is very far from "perfect conditions", and is probably at the difficult end of what most people encounter unless you regularly tow in the mountains.
This is the correct answer.
I concur. But people need to understand that is NOT a 5er as the pin weight will exceed the RAWR. Most likely a gooseneck is what is tested at 18k.
