grumpysmurf's avatar
grumpysmurf
Towing Capacity Question?
Hey guys and Gals, I hate to ruin everyone's Sunday, but I really need some help. I know this is a very frustrating topic for a lot of old timers and a hot topic for anyone who has an opinion. I will give you all the info. that I know at this point. We found a trailer we like(Wildwood T27RKSS).
Dry weight 6500
Pulling at first with a 2000 Chevy Silverado 4x4 with towing package. Vortex 5300, rear axle 3.73, GVW of 6400.
The original drivers door had been replaced when I bought it, therefore no door plate with trailing info. Through research I believe the towing capacity is 7500 -7800. I realize that 300 pound difference is important, so I will find out somehow exactly what the towing capacity is.
With all that said could I pull that trailer safely with a weight distribution hitch.
I know hitch weight is important, but not sure how to find that info?
I figured add 500 pounds to trailer in inventory?
The sticker on my hitch says
max. tongue weight: weight carrying 600/270, weight distributing 1500/680
max trailer weight: weight carrying 5000/2270, weight distributing 12000/5440
Thank you for all info and responses!
  • There is no towing info on the door plate, only the legally required numbers of GVWR, FAWR and RAWR. Pre 2005, the Tire and Loading info label did not exist either.
    Towing info will be in the Owner's Manual if you have one.
    You will need to know the engine/trans and axle ratio to look up the correct number.
