Desert Captain wrote:
Dry weights are worse than useless, never rely on them. With the OP's 8,800 GVWR his tongue weight should be 1,144# + at least an additional 100# for the weight of the hitch. This puts him 300#+ over his hitch limit.
He will not be able to tow his alleged towing capacity of 9,200# as he will have run out of payload long before that. The OP needs a lot less trailer or a lot more TV... it is just that simple. "Light" loading is not going to change the math.
Good luck.
:C
Agreed, you can pull it...you just don't have enough truck to carry it (hitch weight that is).
