kbucky wrote:
The sticker does not list the  weight.  It only gives the standard 1,200 payload number which is shown no matter what options to you add or remove
They already factored in the curb weight, so it's no longer relevant to determining the payload. They did that already...but if you don't believe the sticker, take it down to the scale and see what you really have.
There is no doubt in my mind you will be over the payload limits of that truck.
Will you die instantly if you ignore the good advice that you are overloading the truck? Probably not but you are far less safe and you are likely to wear out and break things at a much faster rate.
