ognend
Jan 10, 2021Explorer II
Boomerweps wrote:
Nope.
The only place Ford refers to a passenger in each seat in the rating is for an IN BED CAMPER, not towing. Before 2021, Ford referred to a 150# driver included in the tow rating, now they add ONE passenger in the tow rating.
Ford does not mention payload capacity anywhere outside of the max cargo weight (limit) for the 2016 towing guide (that I can find anyway). It also doesn't give you the assumed curb weight of the vehicle you bought. All I have on the driver door sticker is front GAWR, rear GAWR and GVWR numbers. The towing guide talks about conventional (bumper pull) towing limit (14,000 lbs) and gooseneck/5w towing limit (15,100 lbs). I suppose they expect you to take the truck to the scales and figure out where you are with your particular trailer and look at the GAWR calculation (as Jerry described).
44,070 PostsLatest Activity: Aug 06, 2026
