ognend
Jan 10, 2021Explorer II
valhalla360 wrote:
Are you sure it's not 2700lb payload?
I know there are some oddly weak payload trucks out there but it would be unusual to find a truck with a 15k 5th Wheel/Gooseneck rating and only 1700lb payload.
Is it some kind of gorped up harley edition where they added 500lb of bling eating up a lot of the payload?
Not saying it would be impossible but a good chance you misread something.
Nope. It is a 2016 Ford F-250 Powerstroke XLT crew cab, 6.7L 4x4 truck with a short bed. If you google "Ford towing guide" and go to the 2016 towing guide and find the row/column for the particular configuration, that's the max payload for camper. The towing guide does not say what the actual max weight can be on the gooseneck pin, I guess Ford doesn't want to publish this information and they leave it up to you to weigh your truck and calculate what you can put on the rear axle?
I just don't understand why Ford can't provide the information online like RAM does for their trucks. RAM has a web page where you can select the exact configuration (engine, trim, 3/4 or 1 ton, so on and so on) and it will tell you what exact max payload is and what max towing capacity is. Chevy will put this info in their new trucks inside the driver door (I have heard). Only Ford refers you to their stupid 20 page towing guide and still doesn't tell you the full story.
44,070 PostsLatest Activity: Aug 06, 2026
