blt2ski
Jan 10, 2021Moderator
"IF" you have a sticker in the glove box that says max bed cargo rating of 1792 lbs, that also assumes you have 3-6 150 lb lbs or however many seat belts you have. So total payload is around 2600 lbs. truck would weigh about 7400 lbs empty.
IF your reading a true brochure, issue with that, is they use a BASE model truck for the most part. ALTHO if it states a platnum pkg, your probably ok to use that number. I've seen the same model truck per say, and crew cab dullies weigh over 600-700 lbs difference between a base, and a loaded leather setup, assuming the same motor cab, bed length etc.
Again, best to weight your truck empty if you really want to know what you have in payload if you can not find enough info on the truck via stickers in glove box or drivers door pillar. I've usually found these stickers to be with in 20 lbs, or a typical scale weight measure use. Most scales work in 20 lb increments, not 1 lb increments.
So pay for a truck registration that is on par to slightly greater than you will weight going down the road, you are good from a State patrol standpoint. I can license pickups here in Wa st up to 20K per axel, or in reality, 500 lbs per inch width of tire. That is around 10-12K per axel for a SW rig. A dual 35 series with usually get 20K on the rear, and upwards of 12K on the front. So ask yourself this question. If you stay with in the manufacture axel weight ratings, will you be truly overweight per the federal bridge laws which is what and LEO is supposed to enforce, along with how much weight you ahve a paid for? Reality, no one will be truly over weight!
If you have a dually class 3 or larger truck, especially class 5 or over trucks, then you have more issues with going over an axel weight than single wheel class 1-3 trucks will.
Marty
Marty
44,070 PostsLatest Activity: Aug 05, 2026
