JIMNLIN
Jan 10, 2021Explorer III
op wrote:
I have been debating moving to one of the new gassers since they seem to have a better towing/payload rating, are cheaper to maintain etc.
Forgot to add this in my replies above but a 250/2500 gasser can have the same rear axle assy as the diesel in most cases.
Fleet Ford specs shows a F250 7.3 gas 176" wb 2wd crew cab rear axle can weigh 2768 lbs vs the same truck configuration with the 6.7 diesel rear axle weight of 2823 lbs = 55 lb difference. Fords empty axle weight numbers are before added options/packages.
Ram and GM gas vs diesel axle weights will be about the same differences.
44,070 PostsLatest Activity: Aug 05, 2026
