rhagfo
Jan 11, 2021Explorer III
Boomerweps wrote:ognend wrote:
Ford does not mention payload capacity anywhere outside of the max cargo weight (limit) for the 2016 towing guide (that I can find anyway). It also doesn't give you the assumed curb weight of the vehicle you bought. All I have on the driver door sticker is front GAWR, rear GAWR and GVWR numbers. The towing guide talks about conventional (bumper pull) towing limit (14,000 lbs) and gooseneck/5w towing limit (15,100 lbs). I suppose they expect you to take the truck to the scales and figure out where you are with your particular trailer and look at the GAWR calculation (as Jerry described).
Wow!
You have a 2016 F250 with no payload sticker. Even my 2008 Explorer has one. The white GVWR/GAWR sticker is required by law, not certain about the payload one. My 2001 Jeep TJ does not have the payload sticker.
The yellow “Payload Sticker” has been a requirement since 2006, has the door been repaired or replaced.
