RoyJ
Jan 13, 2021Explorer
goducks10 wrote:
Who says debris gets spread around in every RV wreck?
All one has to do is rear end someone at a stop sign/light and cause injury.
Only thing messed up is the front of the truck/SUV. The trailer would still be 100% intact.
In this case, regardless of "over-loading", the person would be 100% at fault anyway.
For them to further blame it on trailer weight, they'd have to prove it. It'll likely involve hiring an engineer as an expert witness. Why would they when it takes no effort to prove the driver is already 100% at fault?
Technically everything non-OEM on your truck can be blamed, I don't understand why we always emphasize on trailer weight. When's the last time any of us checked all brake friction materials exceeded OEM spec? What about over-sized tires? Lift kit? Tires with lower friction than OEM? Inertia brake controller at correct angle? Corrosion on electric brake wiring? You name it, with enough money behind a lawsuit, they can lay the blame on!
