rhagfo
Jan 16, 2021Explorer III
spoon059 wrote:
I will never exceed my axle ratings as rated by Ram. My AAM rear axle is rated for 10,120 lbs by AAM, but derated to 6500 lbs as an assembly by Ram. Then because its a Class 2B truck, it's derated by regulation to essentially 5000 lbs. My front axle is rated 6000 lbs by Ram, then because its a Class 2B its derated to essentially 5000 lbs.
You can sue me because my truck weighed 11,000 lbs and claim its "overloaded" according to regulation. I can easily argue that Ram rates my truck to hold 12,500 lbs, and it was not overloaded, it was simply under-registered. Now the petitioner has the burden of proof to show that being over my "sticker" weight and under my manufacturer ratings was overloaded. To make your argument even weaker, in Maryland I can pay to register my 10,000 GVWR truck at a higher rate, thus making it a 12,500 GVWR truck... perfectly legal to drive down the highway.
Well with the Ram 2500 to 3500 you have an unknown in that they have different frames. As far as axle manufacture ratings go the full floating axles used in HD pickups for years going back to to the late 90’s, most have had a rating over 10k, it is the trucks frame that comes into play.
44,070 PostsLatest Activity: Aug 05, 2026
