rhagfo
Jan 17, 2021Explorer III
MFL wrote:
No, your truck did not leave the factory full of fuel. Your selling dealer may fill fuel (mine does). With so many pages of opinions, some facts, can be misleading. Throw in a forum of armchair legal advisors, makes it more difficult than it needs to be.
Your truck's GCVWR, allows for towing a 15K GN/FW, that is a fact! Your RAWR, which includes tires/wheels, axle, and suspension, dictates the load you can carry. I and others, said way early in this thread, that after getting separate axle weights, when no trailer connected, will tell you how much more you can add to the rear axle, in your case, the gooseneck trailer hitch wt.
You have a very capable truck! Again...getting a new gas truck, is your choice, but while it may show a larger number on that payload sticker, your RAWR will be similar, and is what matters.
Jerry
Well MFL you are also giving a forum legal opinion.
To a fact the 15,000# towing rating is what the truck is rated to pull, it may not be able to carry the pin weight associated with that weight. Any F2500 I have read about on this and other forums that even get near max axle rating needed air bags to level due to Ford putting soft rear springs on them.
You also make this statement "Your RAWR, which includes tires/wheels, axle, and suspension, dictates the load you can carry." you have forgotten frame.
In 2021 Ford and GM have started upping the GVWR of 250/2500's to as high as 11,500# at which point they are now a Class 3 truck and should be labeled as 350/3500!
