ognend
Apr 09, 2021Explorer II
IdaD wrote:
If it were me I wouldn't worry about it. In most cases if you throw a set of bags or timbrens on a 3/4 ton you turn it into a same MY SRW 1 ton from a carrying capacity standpoint (provided the tires are also rated for the additional weight). That would effectively give you the higher applicable 1 ton RAWR to work with.
I already have a set of super springs on it. I was more concerned with the actual numbers. Thanks!
44,070 PostsLatest Activity: Aug 05, 2026
