Huntindog
Apr 10, 2021Explorer
ognend wrote:Read my ENTIRE post again. I am not going to contact Ford without your trucks pertintnent info, and challange them on your behalf. It is YOUR truck, and you have the necessary info, and YOU are the one that wants to use your own numbers... If you want an explanation.... Then Ford is your source for it...... If you just want to use the number you came up with.... It is a free country. Just do it, no need to ask about it here.Huntindog wrote:ognend wrote:I "think" that you do not like Fords number, so you are using one that you came up with.philh wrote:
don't like the number on the door sticker, you just get to pick a new number? Interesting way of dealing with payload capacity.
I picked a different number on the sticker - RAWR minus actual weight of rear axle. I feel that number is the right one. What do you think?
Why don't you write a letter to Ford Motor Company with all of the pertintnent info (VIN#) and tell them what you posted here?
Tell them why your calculations are better than the ones their engineers came up with.
Then post their response.
Of course I don't like the number. However, I would also like to understand how they reached the exact 2184lbs payload capacity number (it is not exactly explained in the owner manual) and why they bothered to publish the 6100 RAWR number on the door sticker if the RAWR number has zero relevance. Do you have the explanation for that one? I am not saying this to argue but at the end of the day, if the payload capacity is the single number to look at, why publish the FAWR and RAWR numbers? Thanks!
