4x4ord
Apr 10, 2021Explorer III
Ford gives you the max cargo weight on your door sticker. They also give the maximum axle weight ratings on the door sticker. If you want to follow a maximum rating I’d recommend you ignore the maximum cargo capacity number and go by your maximum rear axle weight rating. I believe it is much safer to be heavy on the pin than light. You could be 1000 lbs over on your maximum rear axle rating and the only way you’d ever know it is over weight is by weighing your axle. If you’re too light, the trailer can be very unstable and dangerous.
44,070 PostsLatest Activity: Aug 06, 2026
