philh
Apr 12, 2021Explorer III
I'm one of the last people I would consider to be a member of the weight police... but here I am.
You want to exceed payload capacity, that's your business.
Are you aware of all the suspension, tires, and axle differences between a higher capacity truck and your truck? It used to be, and it's been a long time since I looked, the 1 ton spring is slightly different to the 3/4 ton, with an extra leaf. I also know there are lower capacity tires available on both models. You also have to deal with GVWR differences between 1T and 3/4T. I believe the rear axle is the same for the same ratio.
You're convinced you're absolutely right and don't think Ford measured things correctly. I will tell you that most OEM engineers are generally top of the heap, getting recruited from all the top schools.
I will also suggest that OEM's sometimes do things for marketing reasons too. Ask me about 2007-2009(?) Dodge Charger RT and the messed up torque mapping pulling a ridiculous amount of torque at low RPM, that was easy to fix with a tuner. It was done to create more perceived separation between RT and SRT.
You want to tow with the truck then go tow.
