JIMNLIN
Apr 12, 2021Explorer III
Ognend....gvwr and gvwr based payload sticker numbers are always a hot item on rv websites. This from another rv website weight thread .....
grindstone01
Senior Member
Registry
*** I'm a retired auto engineer and Marketing has a big impact on GVWR. As a engineer, it was our job to make sure the frame, brakes and powertrain components were designed well above the GVWR ratings that Marketing wanted, so we would design in a safety factor for each component. You don't really think we would build a truck and then test it to determine what the surprise GVWR number should be!
Axle ratings are also well above the GVWR rating and in commercial vehicles, axle ratings are the pay load determining factor and even they have a big safety factor designed into them.
It would be unusual for a lawyer to accept a overweight case unless it was grossly over the safety factor weight and even then a vehicle manufacture would not share that info because it is not a hard fast number that will break if one more pound is added.
There are many videos of million pound plus loads being moved by trucks across country. It's all about the axles.***
Your on the right track...so enjoy the truck/trailer combo. We really like our old '03 2500 Dodge/Cummins HO NV5600 manual tranny pulling our even older '97 11200-11400 lb rv trailer all over the USA.
grindstone01
Senior Member
Registry
