Mcwr? Thats a new one. What is that?
As for add ons? There is absolutely NOTHING that will alter or increase the manufacturers ratings. If you choose to try stuff, air bags are probably the best. But then you have to be careful not to overload the tires or axles. Modifying them could work, but then you next worries would be wheels followed by frame strength. Where does it all end? Transmission rebuild, then front end build, then drive shaft. By that time you will have thousands invested when probably for less money you could have simply bought a newer truck with more load carrying capacity.
