ike1450's avatar
ike1450
Towing Capacity
We just purchased a new 2017 Forest River Salem Hemisphere 299 RE. Dry weight=7,439 lbs, hitch weight=730 lbs.
We own a 2013 Ford F-150 XLT 1/2 ton with a towing capacity of 8,000 lbs and a 3:31 rear axle.
Do we need to move up to up a 3/4 ton with a towing capacity of 10,000-11,000?
R.V dealer informed us, the trailer can be pulled with a 1/2 ton truck, when distribution and sway bar kit is installed.
What is your opinion on this? We normally stay on flat ground, however we're looking forward to traveling cross country.
Thanks,
Deb
  • Your listing dry weight for the trailer. What is its GVW or maximum loaded weight of the trailer. What is the payload rating of the truck.
    There are more parameters to be concerned with than just the max. tow rating.
    All 1/2 tons,better yet, all trucks are not created equal. Each truck has a sticker on the door jamb that list the ratings for that particular truck. Your F-150 will have a sticker.
    On the surface it seems like you need more truck or less trailer.
  • Keep the trailer GVWR within the tow rating for best results.
    Forget dry weight unless you are just transporting empty RVs to the dealer.
  • What is the payload capacity of the Ford? What will you carry in the Ford besides yourself? How much will your WDH weigh? The salesman said....hmmmm. "Pulling" isn't very relevant. Wet/loaded I'll wager your TT will be 9,000+ with a tongue weight of...1,100 to 1,300 pounds.
