MFL
Jun 30, 2019Nomad II
Welcome to the forum! A 2015 F250 will do the same job as a 2015 F350 SRW. They are the same truck with different class rated GVWR. The 250/350 diesels generally have the same tires/wheels and axle. Some 250 models, even the same springs. In any case, if you have found a nice 2015 250, it will easily work for the size FW you are talking about. If you need more truck, due to getting a large FW, a 350 DRW will be required, rather than a 350 SRW.
Jerry
Jerry
