MO Traveler wrote:
So how much of the tongue weight is taken off the truck with a weight distributing hitch? If I have a 700# hitch weight what actually ends up on the truck when properly dialed in? Also what are opinions on the best WDH with sway control?
Exact amount, I don't know, but, it is not a significant amount. The primary purpose of WDH is to restore lost weight from your front axle.
When you hang the tongue weight on back of your truck, it pushes the back end down and raises the front end (removing weight). WDH distributes a small amount of weight back to the trailer axles, restores lost weight on the truck's front axle, and leaves the remaining weight on the truck's rear axle. When you consider the weight of the WDH itself, there is little, if any, reduction on the payload impact.
Other things to consider:
Don't bank on advertised weights and capacities.
You're going to run out of payload, before you get close to max tow weight.
If you're getting that 1600 lb payload from the owners manual, it may not be correct. Could be a generic number for 1500 Ram in general. Check your drivers door post for a tire / loading sticker. It will show a number for your specific truck. In the last week, there was a poster who read one number in his owners manual (Ram 1500), and another number on his door sticker.
Advertised trailer weights will go up, before you drive it off the dealer lot. They will go up when you load dishes, bedding, and camping gear, and go up more when you load water and groceries.
Holding tanks, depending on their location (in relation to the trailer axles), will raise and lower your tongue weight. Note: My fresh tank is behind the axles and my galley tank is in front of the axles. My tongue weight can fluctuate as much as 200 lbs during every trip.
Payload is used up by the weight of aftermarket accessories (bed covers, bed liners, undercoating, floor mats, luggage racks, etc), people, pets, cargo (in the truck), WDH, and trailer tongue weight.
There are several WDH's that will do the job, if the truck and trailer are well matched. Do a search on this form, you'll find several threads, discussing various brands.
