WeBeFulltimers
Nov 26, 2014Explorer
retispcsi wrote:
OK I have all of the goodies, a great exhaust brake, disc brakes on the trailer dually 1 ton with great brakes etc. The situation you describe is not uncommon. It does not matter if you have a ten ton hook that will fly out the back of the trailer on a panic stop if you do not leave enough spacing between you and the guy in front of you. You said you over estimated you speed and that is a large part of the problem. The trucks we drive will pull almost anything. The real problem is slow down and drive defensively.
Ding Ding Ding......This is the correct answer!
44,068 PostsLatest Activity: Jun 27, 2026
