norfla71's avatar
norfla71
Towing heavy with a single wheel 3500
I'm looking at possibly upgrading to a larger and heavier fiver in the future (Columbus 385BH or similar) and each one is right around 13k dry/15k GVW, some pushing 16k gross. My current fiver is around 12,000 as we tow, and the truck seems to be pretty happy with it. I'm looking at a set of dedicated HT tires (265, 3 steel belt Duras) for more stability, but am concerned I may need to convert to duals for pulling. I know I've seen a couple of 3/4 pulling 3 axle TH, so it can be done, but should it? Truck will have bags before commiting to the rig, along with a Pacbrake.
We plan on pulling all over the country, so there will be a lot of hills and mountains.
  • The nice part about the Columbus 385BH campers is that they're very pin light. I have a similar layout and my pin weight is only something like 17-18% depending on my load.
    Doing the math on the Columbus 385BH, I think you can realistically expect about 18-19% pin/hitch weight which should keep you within specs on the truck itself.
    Columbus 385BH Pin Weight Calculation
