All_I_could_aff
Dec 22, 2019Explorer
Twistedlarch wrote:All I could afford wrote:
You may need to adjust brake controller settings. It can be tough to modulate gently to avoid lockup on slick surface
This is one of my concerns, should I adjust controller to where I don't feel the trailer brakes? It is a relatively light trailer at just 3800 lbs.
I usually just lock the truck into a low gear and coast to avoid breaking all together.
Brian
I’m thinking more the adjustment for how abruptly it applies the brakes, but I agree to minimize the need for brakes, especially while turning.
Even though your trailer is only about 3800 pounds, that is spread over just the one axle. Similar weight on each tire as a 7,600 tandem
