carringb
Dec 23, 2019Explorer
With my prior Weekend Warrior, I'd dial down the brakes a couple volts, otherwise they could lock up.
Current trailer has 50% less braking, and even under hard braking in the snow, it won't lockup the trailer tires even without chains. The brake controller experiences less deceleration anyways on snow, so it it'll already be sending out less power.
Also be careful engine braking on slippery roads. You effectively has less tires slowing you down, but if you start to lose traction, you have to add throttle to recover and that's not very intuitive.
