tjw0099
Oct 12, 2014Explorer
Towing issue
I have an 06 Ram 1500 4.7 8 cylinder capable of towing 6500 lbs. The trailer is 5250 - loaded figure 5700. I have the old school sway bar hitch. There is no up/down adjustment for the hitch or ...
sch911 wrote:
You may be confusing a weight distributing hitch with a sway controlling hitch. Those bars with chains are for distributing the weight into the tow vehicle not sway control. Sounds like it's not setup correctly or you're not connecting the chains correctly. Are you jacking up the TT's tongue jack prior to connecting the chains? Generally this type of setup would be used with a friction sway control mechanism.
