tjw0099
Oct 12, 2014Explorer
Towing issue
I have an 06 Ram 1500 4.7 8 cylinder capable of towing 6500 lbs. The trailer is 5250 - loaded figure 5700. I have the old school sway bar hitch. There is no up/down adjustment for the hitch or ...
Terryallan wrote:Some people consider a 2" drop to be unacceptable.
A 1 to 2" drop does not a V make. that is in truth not much of a drop at all, and would barely be noticeable.---
there is a reason the WDH instructions tell you the rear should not be HIGHER than it was unhooked.The WDH instructions warn against adjusting the WDH to make the rear end higher.
