tjw0099
Oct 12, 2014Explorer
Towing issue
I have an 06 Ram 1500 4.7 8 cylinder capable of towing 6500 lbs. The trailer is 5250 - loaded figure 5700. I have the old school sway bar hitch. There is no up/down adjustment for the hitch or ...
Terryallan wrote:Ron Gratz wrote:Terryallan wrote:Some people consider a 2" drop to be unacceptable.
A 1 to 2" drop does not a V make. that is in truth not much of a drop at all, and would barely be noticeable.---
If they want to use air bags in conjunction with a WDH to eliminate the drop, that's their prerogative.
They do need to use the air bags correctly so they don't interfere with the load transfer.there is a reason the WDH instructions tell you the rear should not be HIGHER than it was unhooked.The WDH instructions warn against adjusting the WDH to make the rear end higher.
Doing so would mean you have transferred too much load to the front axle, and removed too much load from the rear.
Using air bags to restore the rear end to its unhooked height does not cause load to be added to the front tires, and does not remove load from the rear.
Ron
Ron. I think we agreed there. Especially on the WDH shouldn't raise the rear too high thing.
However. I would only consider it a V if the headlights were hunting coons. Meaning no weight on the front.
