ah64id wrote:
You are not the OP, and based on your Owners Manual I would guess you have a different vehicle. Good job checking your own manual out, vs just reading and believing.
Hahaha, this guy...I tells ya. You may want to take your own advice and read the entire thread. The OP has an 07' 1500 Hemi. I have a 08' 1500 Hemi. Both trucks are in the same generation (3g). Not only are the trucks in the same generation, they're also in the same sub-generation (06'-08'). There's no significant differences in weights and measurements between an 07' and 08'. Actually I don't think there's any significant mechanical difference between the 07' and 08' 1500. Not only that, both of our truck have the same gear ratio (3.92). If I had to guess, the OP's also running 20" wheels (same as mine).
