Hey All, I'm brand new to this wonderful world and want to thank you all for all that you contribute to this site. I've learned so much and am so eager to continue to learn. Now we just purchase...
I justed looked at that unit online and see it has a dry weight of approx. 2830lbs. So yes, anything with a 6000 lb towing capacity should be more than fine. Loaded to the max your tongue weight would be under 400lbs, and the unit being under 20 feet, you would be fine with a six cylinder you described.
Check the CCC of any vehicle you look at (yellow sticker on driver door frame).
