Meechy
Aug 28, 2015Explorer
Towing Newbie
Hey All, I'm brand new to this wonderful world and want to thank you all for all that you contribute to this site. I've learned so much and am so eager to continue to learn. Now we just purchase...
eluwak wrote:
The problem isn't cooling, it's radiator failures that cross contaminate the trans fluid with coolant and it destroys the trans pretty quickly. Nissan extended the warranty on the radiator, but if it destroyed the trans they were denying folks the trans repair. The best way to fix it is to bypass the radiator, install a gauge, and then see if you need an aux cooler.
It should do fine, but install some airbags in the rear to keep it off the ground. And like said, don't be afraid to tow in 3rd for extended periods of time. Ours had no problems holding 60 mph towing a TT too big for the truck.
