- Passin_ThruExplorerI replaced my GM hitch with a Reese 12k. GM had almost rusted thru.
- bobndotExplorer III
6.7 tow rig wrote:
bobndot wrote:
If I absolutely had to make that exit , I would disengage my WDH and sway bar so additional stress on the TT frame is minimal.
So every time you pull into an uneven gas station, food stop, etc, you disengage the WDH? It must take you months to get somewhere. That doesn't appear to be that steep to me. Almost every trip we encounter some sort of uneven entrance exit.
:B Im always the last one to arrive.
IF I had to..., I think I would remove the bars . But I would not put them back on until I gassed up again. I have a lot more TV than I need, the WD bars do not make a difference in my ride. I really don't know why I put them on in the first place.
I towed my 4 place snowmobile trailer thousands of miles and didn't use WD bars either. I did need them on my 37' , 31' and 30' TT's but the TT I have now, has no slide and aluminum skin. - 6_7_tow_rigExplorer
So every time you pull into an uneven gas station, food stop, etc, you disengage the WDH? It must take you months to get somewhere. That doesn't appear to be that steep to me. Almost every trip we encounter some sort of uneven entrance exit. - stufarmerExplorerI've seen this failure before. They are far and few between, but it appears to be another Lippert Frame failure. And why I've never own one.
- bobndotExplorer IIIIf I absolutely had to make that exit , I would disengage my WDH and sway bar so additional stress on the TT frame is minimal.
- PAThwackerExplorerA frame failure. Everyone shooting out about jumping off the ball.
- profdant139Explorer IIIMake sure the collar under the coupler is engaged, every time. Don't ask me how I know this.
- CavemanCharlieExplorer III
Old-Biscuit wrote:
DutchmenSport wrote:
That looks so sad, I had something similar happen to me. It's not fun at all ... none. I've posted this before:
OUCH :E
X2 Egad. I would be pissed. What a horrible designed TT and bad welding job for that to happen. - CavemanCharlieExplorer III
rockhillmanor wrote:
To begin with on a 45 degree angle of 'that' steep driveway he shouldn't have been taking it straight on. I and most RV'ers would not have even gone in a station with that steep of a driveway.
I think the driveway has a lot to do with it putting more stress on the ball then rated and popping it.
Doesn't look that steep to me. But, maybe I am not seeing it correctly. - rockhillmanorExplorer IIITo begin with on a 45 degree angle of 'that' steep driveway he shouldn't have been taking it straight on. I and most RV'ers would not have even gone in a station with that steep of a driveway.
44,070 PostsLatest Activity: Sep 18, 2026
