Pam_s_Dennis's avatar
Pam_s_Dennis
Towing our chosen TT
We are going from a class c to a travel trailer and are curious about a tow vehicle. The chosen TT is a Flagstaff 25KS and we are trying to find a used but not abused Ford F150 Ecoboost or a Dodge 1500 Ecodiesel. The tow vehicle will replace our Honda Odyssey. A 2004 Honda CR-V is our errand runner around town. We do not want to purchase a new truck so it is likely that the Ford 150 Ecoboost will end up in our driveway. I haven't seen too many Dodge 1500 diesels on the used market yet. Scarce as hens teeth. Any comments about the Ford or Dodge or any other tow vehicle will be welcome. We are looking at economy and do not want the constant maintenance of the motorhome even when not in use. The only towing done in the past was popup and then we jumped into the motorhome years later and towed the Honda CR-V. I do not like towing and not being able to back up without disconnecting the towed vehicle.
  • I did a lot of home work before buying my 5.0L F150. I wouldn't buy either of your choices.
    The Ram Ecodiesel is really just a grocery getter with no payload to do any real work. The payload is less than 1000 lbs so you really can't have a heavier tongue weight and people in the truck at the same time without going over GVWR.
    The Ecoboost was offered in 2011 - 2014. All models of the Ecoboost have had some serious problems but earlier models were worst. From the complaints I keep reading, Ford never corrected the condensation problem that happens in the intercooler and causes the truck to stall and go into limp mode on expressway and highway, full throttle situations.
    They CAN also have carbon build up issues from the direct injection (as other direct injection engines do) but it's worse when carbon breaks off as it could damage the turbos.
    Also early models had spark plug gap problems. Do some google searches to see for yourself. BTW, Ecoboost Crew Cab 4WD has a lower payload than the 5.0L Crew Cab 4WD for some reason. Ecoboost only has a 7200 lbs GVWR while the 5.0L has a 7350 lbs GVWR.
    If you must get an Ecoboost, I wouldn't get any earlier than 2014. As far as getting any 1500 Ram, none have any payload. The Ram 1500 Crew Cab 4WD trucks have a very very low 6800 lbs GVWR. You'll be running out of payload with a heavier tongue weight (any TT) with people in the truck.
    I would recommend a 5.0L or 6.2L F150 with careful payload considerations or a 5.0L with the Heavy Duty payload suspension package. Better yet either a a Ram 2500 or a Ford F250.
    I really love how my 5.0L tows my trailer. A lot of lower rpm torque and upper end power as well. Just get the 3.73 axle with the 5.0L. Here's a review how great the 5.0L tows.
  • I had a 2012 F150 with Ecoboost. Plenty of power and torque to tow my Heartland Trail Runner 27RKS. The engine was never a problem. I ran out of Payload as soon as I hooked up. Granted, my Travel Trailer was a little heavier than yours but I had to upgrade to a 3/4 ton truck so I would have Payload left to work with.
  • 25KS - Micro Lite Travel Trailers
    Just to be sure this is the trailer you are looking at? GVWR is about 6,500# so roughly a 800# hitch weight when fully loaded. Most people run out of cargo capacity be fore they run out of tow capacity.
    Depending upon the year and how the individual truck is spec'd (regular cab vs crew cab, engine/trans, type stuff) it's doable. Need to read the drivers door sticker for the trucks GWVR. Most F150's have a cargo capacity of 1,500 to 2,500# so depending upon truck configuration, how many people and how much stuff you stuff in the bed will determine if it' doable.
  • I have not seen any real numbers on the Dodge 1500 Diesel when towing; but do not expect to get much better then about 10 MPG when towing with any gas set up.
