prichardson wrote:
I have not seen any real numbers on the Dodge 1500 Diesel when towing; but do not expect to get much better then about 10 MPG when towing with any gas set up.
I tow 21 feet of Palomino behind something close to a Dodge RAM ecodiesel. A 5000# AWD VW Touareg with a 3.0 TDI motor, pretty much the same specs as the RAM 1500 Ecodiesel, if in 2wd version and an extra cab, not a crew cab. 240HP 406 ft lbs of torque on the Touareg.
I see 16.5 to 19 MPG towing. My trailer has 14" rims and tires, so I am bound and limited with the 8 speed transmission, to towing at 55 MPH MAXimum speed, due to the specs on the tires. If I am at higher elevation and the interstate I am on is a fresh repave, under optimum conditions with a 10-15mph tailwind, I will pick it up to 57 or 58 MPH, but never, ever faster.
Start towing much faster, or get a 20 or 30 mph winter head wind like I had going west on I-40 through New Mexico one December, and 12 MPG and 45 mmph tops becomes your real world situation, with a huge suck on your wallet and fuel tanks and fillups.
My Touareg holds 26.5 gallons of fuel, it's good for 400-450 miles between fillups trailering, most of the time. One days worth of driving, as far as I am concerned.
The RAM will not do quite as good as this, take 40 to 50 miles off the range between fillups, it just does not have the CD drag and aerodynamics that the Toureg does as a Sports SUV. Also the Palomino Gazelle I own is but 7.5 feet wide and has a sloped top of the roofline to it, which also helps the MPG.
The RAM ecodiesel is brand new in 2014, plan on buying new, if that's what you want.
Now then, when I am not trailering... 80-85% of the miles so far accrued on the Touareg... 30 to 35.5 MPG all the time on the highway at 62 MPH set on the cruise control. I did a trip this weekend down to San Diego, 340 miles, and the MFI gauge is showing 38.2 MPG so far on this tank of fuel. I'll know more after I fill up and hand calculate it via pencil and paper, if that is a true number, but I am expecting at least 37 MPG out of that tankful, probably a 9 gallon fillup, or a touch more, max. Speed will kill your MPG's. It doesn't pay to drive fast unless for me, I need to make over 600 miles in a day, a few days in a row, where then lodging expenses per night while not trailering exceed cost of additional fuel spent. Being retired is nice.
If you drive the RAM nice, and slow it down, say 65 MPH on highways and freeways, I'd think 30 to 32 MPG is possible in the summer time, in the mountains, with the AC turned off. All bets are off if you haul AZZ at 75 -80 like most idiots with the AC on. 25 mpg, tops, with the tailgate down.
