ejd43's avatar
ejd43
Towing questions
Hello my fellow campers! New to the forum and I figured someone here could help me with a concern I have. Last fall we had upgraded our camper, we went from a hybrid to a 32 foot travel trailer. While towing it home I watched all my temperature gauges to make sure all was well. My transmission temp sat around 160-170 on the 4 hour drive home, and the oil temp stayed around 215 degrees, engine temp was normal as well. However, towing it from winter storage to our campground a few weeks ago I noticed everything was still in good range except for my oil temperature. It was 248 in just the hour trip from my house to the campground. My question is, would it be wise to install an oil cooler, or should I run better oil in my truck? We have one long haul trip planned in July, it's only 6 hours but I don't want to compromise my truck in the process. Any suggestions would be very appreciated.
By the way my truck is a 2013 Ram 1500.
  • Most vehicles with "Towing packages" include an oil and transmission cooler. Most, Not all. So check to see if you have them. If not, I would add them as keeping those lubricants cooler and not breaking them down IS the safeguard to not damaging the engine and tranny.
    Checking your payload number on the drivers side door sticker against what your tongue weight, passengers, hitch weight and anything else you add to the truck in the cab or bed will tell you if you have miscalculated and have too much trailer for your truck.
  • My apologies, the camper is a keystone cougar. Unladen weight is 7,000 lbs. It says my max is 8500 lbs that I can tow according to the chart. I really hope I didn't miscalculate what the truck can actually haul.
  • You say a 32' travel trailer but don't say either the weight or make model etc.
    Check the yellow sticker inside your truck door for the towing capacity info, as well as checking the info for the trailer. A 32' trailer could be a 27' box with 32' total length or a 32' box. Weight range can be anywhere from 6,500 to 12,000 depending on model.
    Ram 1500's can be pretty light on their towing capabilities so try to find your capacities. If you saved the window sticker it should tell you what, if any tow packages you have.
    A quick google search found this.
    2013 Ram
