Mr_MrsSchlepprock250 wrote:
I know I'm opening a can of argument here but if your rig is set up properly you won't NEED a sway bar..JMHO Dead level is good, but a little low in the front of the TT is good too. The axles of our TT are almost center, so like I said we load a little front heavy to add tongue weight.
X2 We have a 2500 diesel towing a 35' TT 9000 lbs. using a WD hitch and no anti sway......system. Semi's are no issue no sway at all.
Make sure your hitch is set up properly. Raising the ball to "level your rig" does not mean the weight is evenly distributed between all 4 axles. Search the net, there is lots of info on how to set up a WD hitch.
Good luck and happy camping.
