ib516
Aug 22, 2013Explorer II
Towing report
I just got back from a 1500 mile trip, pulling the 5er about 1100 of those miles. The set up is as below in the pic, and the 5er is 37' and weighs around 11500#. I have weighed it several times. ...
720Deere wrote:ib516 wrote:720Deere wrote:
If your combination weight is 21,000 and your trailer weighs 11,500 of that then your SRW truck weighs 9,500 lbs? That seems a little steep even for a dually let alone SRW. The reason I bring this up is lately I am seeing a lot of people say their trailer weighs Y and their combination weight is Z but Z-Y= a number that seems too large for just the truck. Is everybody simply taking the trailer axle weight and saying that is the actual trailer weight?
Truck had 150# genny and spare LPG tank in the bed, 100# dog and 5 people in the cab, etc...
When fully loaded and hitched up, the truck comes in around 10,000#.
So this includes the pin weight?
Yes.
Last time I actually weighed the whole combo all hitched up, then unhitched and weighed again, the RV was just over 11,300# and the truck was 10,000# loaded & hitched, 7800# loaded (genny, LPG, 3 passengers) and unhitched. Pin weight was around 2200#. Going from memory, so all numbers are approximates. I also have to convert all my scale weights from Kg to lbs so my American friends can make sense of them :) so they all come out to odd numbers.
Again this tells me that the trailer itself weighs around 13,500 if you include the pin weight which is actually part of what the trailer weighs, not the truck.
Trailer is 11300 - 11500# by itself, 9100 to 9300# axle weight plus 2200 pin.
The truck (without passengers, 5er hitch, and cargo) weighs ~7300# last time I scaled it.
Tomato/tomatto I guess, but the 2200 lbs is part of the trailer's actual weight even though the truck ends up carrying that weight. If the trailer wheels only carry 11,000 lbs and the pin weight is 2,000 lbs, you are still towing a 13,000 lb trailer.
