DutchmenSport wrote:
DanNJanice wrote:
... The faster you drive the more time to stop, the heavier you are the more time to stop.
True... and remember, time equals distance you know. It takes more distance to stop a 15,000 pound 5er, than it does to stop a 3,000 pound car. You may be able to stop the car at 60 mph in 200 feet; the 5er at 60 mph may take 1000 feet!
Actually a loaded semi can stop in less distance than an empty one.
A typical car takes about 300ft to stop at 80 MPH while a loaded semi at 55 takes about 300ft also. That does not include distance traveled while either driver is recognizing the hazard and the reaction time distance after a hazard is recognized.
I know I can stop my 5er at 60 in less than 300ft(a football field) also. 1000ft is over three football fields.
My truck and my 5er both have about the same weight on each brake. 2,000 on each trailer brake and about 2000 on each truck brake. So hooked or unhooked I am stopping the same weight per brake surface. In fact, with the 5er hooked up the rear truck tires have a better bite and will stop sooner.
