Jessie727's avatar
Jessie727
Towing with 1993 chevy c1500- Weight?
I have a 1993 c1500 with a 5.0 in it. My fiancé and I are buying a camper to live in while we build our house and I was wondering what is the max weight I can tow with my truck from the bumper verses the max weight from a 5th wheel. We don't plan on moving the camper except across town when we change lots, or to a few cities away incase of a hurricane. With that said, we'll always be driving on flat ground except for a handful of bridges and never go further than 100 miles away.
Thanks in advance to anyone who can help
  • ANY truck, will always have less 5w capacity than bumper pull. If you have 1000 lbs of payload, max 25% HW for a 5w, that equates to a total of 4000 lbs of trailer. If you do a bumper pull with 10% HW, you now have 10K lbs of trailer to work with.
    Your truck probably weighs around 5000 lbs empty, you have a gvwr of 6000-6600 or so, so max payload after loading you and GF, is around 1000 lbs. Now will your TBI5.0 v8 with maybe 175 HP tote a 10K trailer well.....that is up to how you feel your power to wt ratio is. A 5.0 with 3.42 gears, gm gave it a 10K rating max. If you have 3.73's, it will be 11500, 4.10s 13000. BUT, you are over warranty, so per most if not all state laws, max trailer capacity per the manufacture is a non legal issue.
    I personally would not tow more than 2x the grawr of your truck, which is probably 3000-3500 or so, maybe 4000, so 6000-8000 max. I would also not worry about the 3.42 gears, as your trans has a lower ratio in first than a 2500 like mine with 4.10's, your actual initial overall low take off ratio is lower than mine! You also probably have smaller diam tires, so that lowers the ratio even more.
    SHort trips are not always a killer, need to have a high hp motor.
    Marty
  • 1993 Chevrolet/GMC C1500 Pickup (2WD) 5.0 V-8 6000
    Requires 3.42:1 axle ratio.
    Requires Z82 Trailering Special Package.
    Requires automatic transmission.
    Requires engine-oil cooler.
    Requires transmission-oil cooler.
    Requires weight-distributing hitch.
    Towing not recommended with GMC Typhoon.
    The 6,000 lbs. in the upper right corner would be maximum, using all requirements.
    Jerry
