VentureVan wrote:
I don't foresee a problem with sensible driving as I will be well under the rated towing capacity.
Actually, you will not be well under the rated tow capacity.
The manufacturer rated that capacity, considering the vehicle had a 150 lb driver, with no aftermarket accessories, no cargo, and no passengers.
As you add weight from accessories, people, and cargo, that rated tow capacity is dropping, pound for pound. Just adding the E2 hitch, will take close to 100 lbs of tow capacity away.
If you load the hitch and 500 lbs of people and cargo, your real tow capacity is 2900 lbs. Load 700 lbs of people, cargo, and hitch, your max tow rating would become 2700 lbs.
Now, look at the trailer:
It has an advertised 2133 lb dry weight. Dry weights are rarely accurate.
Average weight of stuff we drag along (dishes, pots and pans, bedding, camp chairs, BBQ, a few tools, groceries, and water, etc) weighs 700 - 1000 lbs.
If the advertised dry weight is close to accurate, adding a battery and propane will push that up to 2200 lbs. Conservatively, you will add another 6 - 700 lbs. That gives you a loaded trailer weight around 2900 - 3000 lbs.
Rather than being well under your tow rating, you could be over.
